- Jan 25, 2001
- St. Louis(USA)
I was talking to someone in television and he mentioned a cooling set up that a tape recorder used. In stead of a common heatsink and fan they a copper pipe between the chip and board. The copper pipe then led to a heat sink and fan, but the cool part was that the copper pipe was hollow and filled with liquid sodium. The liquid sodium conducted the heat so well that no pump was needed to circulate it. This one set up was also good enough to cool multiple chips per pipe and heatsink. This got me thinking about new ideas about cooling. Using this set up you could effectively remove most of the heat from your system. The only problem is how to adapt the copper pipe from underneath the chip to above the chip.
P.S. I think it was liquid sodium.
