- Feb 13, 2001
- Twin Cities
The marriage between this HSF and my Duron has yielded some interesting results. I have been able to lower many of the voltages I previously used at the different speed steps I have tested at.
I spent most of the evening testing and did not get to the 3 terminal regulator for lowering the speed yet.
I have attached some graphics that speek better than my words. Your results may vary as a lot depends upon the grade of your CPU. By that, I mean, some just seem to work better than others for OC. I feel I came out on top of the "luck of the draw" with mine.
These results were obtained with a room temperature of 18C and inside the case was running 19C.
I will post a more brief set of results when I lower the fan velocity.
Hoot
Hoot
