Swiftech allin one?
Boulard83
:welcome:
yep. Its new from swiftech.
But its not a complet kit. You still need tubing/cpu block/clamp.
Spawn-Inc
you are somewhat limited to mounting options but i think its a great idea and should be helpful to those starting out.
Conumdrum
Small town Emlenton, PA
It's pretty expensive. You can buy a 120x3 rad for $55 and a great pump for $65 and a res for $25. But it's pretty neat if you don't want the pump and res seperately.
J-O_S-H
England, United Kingdom
Hmmm... That does seem expensive for what your getting.
The Swiftech Apex Ultima XT seems like a much better option.
It's about $260 and includes everything almost.
You get Apogge XT waterblock (one of if not the best waterblock available)
MCP665-b pump
MCR220 (2x120mm rad)
Swiftech micro res
Tubing
Radbox
Coolant... unsure on what this is... probably better to use distilled + PT Nuke/SIlver coil or if a premade coolant is neccessary... TC EC-6
hokiealumnus
Water Cooled Moderator
Holy crap....I had no idea they'd be that expensive. If room is a key concern, I'd say they're a good idea. But at that price point, I'd recommend anyone with room to go with a separate MCR320, MCP355+top or MCP655 and the res of your choice (or go with an MCP355 + XSPC res top and kill two birds with one stone).
