reviews said that this HS have the lowest risk of cracking the core..... is this so? (i'm getting a shim anyways.). should i stick with the stock fans or up to a delta? what other air cooling (except for the MC461) HSF can best the MC370 provided it would be as easy to install? thanks for your help.
edit: using this to cool a tbird 1.2ghz 266fsb. (of course i want to OC it.. i want it to fly at least 1450+mhz!) if you have another HSF suggestion, please be one that would fit an Iwill KA266 mobo. thanks again!
