swiftech or aquastealth2
RJ
Michigan ,USA
OK I,m running at 39*-40*c idle 43-44*c with prime95 should I leave things as is or go with either the mc462 or aquastealth 2 with the cube radiator? I have a small mid tower case so I'm kind of conserned about where everything will go.any ideas? A7V133 1.2Tbird@1454mhz FOP38, enlight 7237case ,300watt psu. 3- 80mm 36cfm input fans ,2-80mm 36cfm output fans, plus a slot card cooler fan.
i will assume you have an AMD socket A cpu(duron or TBird). if so, then you have a tough choice. Water cooling is harder to set up and more expensive, but will yield better results than the MC462. The MC462 is $80. You might want to try the new CAK38 from Globalwin, it is all copper, aroound $35, and is as good as the swiftech MC462, and nearly as good as water cooling. That would be what I would do.
