i'm considering giving my mc1000 another whirl. i had a oc'd 300A celeron that used an asus S370 slot 1 converter. it came with the mc1000. when i moved my cpu died. after removing the mc1000 i saw there was oxidation on the cpu. sudden death syndrome explained.
1 have you guys gused the mc1000 without problems?
2 what could i have done differnetly?
3 conformal coating? what do you spray? just the asus board or the cpu as well? what should i not spray? =)
4 how much better is the mc1001 in your practical experience?
5 do i just need the standard upgrade kit (without backplate) for 1001 to go from my old celeron socket to a p3-850 socket?
6 how does the mc1001 stand up to other peltiers? perhaps i should just try a new brand.
7 how do you get a good cpu temp reading? is that built into the motherboard somehow? or are there probes you must insert under the heatsink?
8 any other advice/comments are welcome. some of these questions i posed to swifttech but i just thought i'd get the forum's expertise as well.
thanks for you advice.
here is the swifttech url in case some of you are wondering what heck i'm talking about.
