- Apr 17, 2001
- Springfield, IL
I usually have a clue, but this one has got me.
I have DSL. The modem is connected to the WAN port of a Netgear RO318 router/8 port switch.
This switch is setup to be the DHCP server. From there I have Cat5e run to wall jacks throughout the house. I then bought a Dlink 704P router/4 port switch with print server. I want to connect it to a wall jack in the living room, connect a computer to it, then connect a network printer so I do not have to have that computer turned on to print.
Should be simple, connect a crossover cable from the wall jack to any LAN port on the Dlink 704P and a patch cable to the computer. Turn of DHCP on the Dlink 704P and set a static IP for it.
Does not work! The computer will not get an IP and I can not ping the Dlink. I do not know why.
I tried a straight through patch cable instead of the crossover. I tried connecting both to the WAN port. I set the Dlink to be a DHCP client, no IP. If I set the Dlink to be a DHCP server the computer will get an IP and I can talk to the Dlink, but nothing else on my network.
Ok, I asked a friend, he suggested I connect it to my hub. I have a 16 port 10MB IBM hub, purchased from {PMS}fishy. The hub is connected with a patch cable (not crossover) to a wall jack that is connected to the Netgear RO318 in the basement. It has 3 computers connected to it with no problems, they get IPs from the Netgear. I connected a LAN port on the Dlink to the Hub with a patch cable, then connected a computer to another LAN port on the Dlink. The Dlink has DHCP off and a static IP (192.168.0.200) Reboot and I have IP. Can ping and talk to both the computer and the switch from any computer on my network. No problems at all.
What gives? Anything I forgot?
Note the links to the manuals, if needed.
