- Aug 17, 2002
Hi all,
Just got Symantec's PCanywhere, and i've got it working fine for remote connections across my LAN. HOWEVER, I cannot seem to get the "remote management" part to work. This appears to be the part where you can do such things as lock the screen and start services.
The ordinary logon for the computer works fine, but then you have to put in another login for the remote management section, which also asks for a domain. I enter the usual username and password.
I've looked in the help file, and it says as step 1 for entering logon credentials: In the Remote Management Properties window, on the Host Login Credentials tab, type your user name..
However, I do not HAVE the "Host login credentials" tab...
So, I'm just wondering how to get it to work... When I try and connect, I get this:
Even though I'm already connected to that computer for the normal connection...
Any ideas?
Any ideas?
