system clock keep changing
htuong
Sacramento, CA
Hi all,
I hope you guys can help me out. I don't know if this is a windows problem or a motherboard problem. I have:
Sis K7S52A mobo
1x 256 ddr ram
40 gigs wd hd
Windows Pro sp1
The problem that I am having is my system time is not accurate. Every time I set the right time, in a day or two it will be off by couple of hours. I had this problem for about a year now and I am tried of changing the time back every couple of days.
I don't think it is the mobo's battery because I only had the board for less than a year. I tried reinstalling Windows but it still has the same problem. Any help will be great. Thanks in advance.
DDR-PIII
Disabled
6p6
make sure it's setin the same timezone as you are, cuz if it isnt it'll update from the internet and itll be idfferent.
redduc900
Inactive Moderator
Portland, OR
In addition, it could also be caused by a weak CMOS battery (even though your board is less than a year old). You could also try this...Start | Run | Type cmd and hit OK | At the command prompt...
1. Type net stop w32time, then press Enter
2. Type w32tm.exe /unregister, then press Enter
3. Type w32tm.exe /register, then press Enter
4. Type net start w32time, then press Enter
The above listed commands re-register the information regarding your computer's processor clock, which is stored in the Registry. ;)
twump
CA
i would bet money its the cmos battery. k7s5a's are notorious for shipping with basd batteries. the first k7s5a i had had the same problem. goto kmart pick up a cr2032 watch battery and you good to go
SniperXX
Folding in Diamond Bar
Does the Bios have a voltage reader for the CMos bat? If so check it before you buy a battery, you dont want to buy one if its not the battery even tho it may be.
My $0.02
skab
Montevideo, Minnesota
If the time in your Bios was set differently from the time in Windows then you'd have the same kind of problem, but that's a simple check.
