i ran my system with sisandra soft with high priority for 30 passes and it didnt reboot .. but when i play a game or starting up my file share program it fully reboots with out any warnings..this started to happen after i put my xp +1700 cpu in and maybe when i unlocked it ... does unlocking it worn gcause system to reboot with out warning ??and im not overclocking at the moment ..
heres my specs..
msi k7t turbo
+1700 xp @1.45g
pc133 /396mb
couple drives
40 gigger maxtor
some fans and some neon
my power supply is powertech 350 watt and the numbers seem to be ok aby sy=uggestions??should i take nail polish remover to the cpu???should i put my thunderbird in instead and see if it cpu related?there seems to be not much problems with this bored with a xp cpu so i dont want to mess with something that wont fix the problem ..please help thanks -cat-
heres my specs..
msi k7t turbo
+1700 xp @1.45g
pc133 /396mb
couple drives
40 gigger maxtor
