I have been having a great number of problems recently. In windows, the system freezes, reboots, and sometimes screen turns black with a broken green line across the top. I installed some updated video drivers a few days ago, but I reinstalled my old ones. What could be causing the black screen/green line problem? I have never had that before. What other problems could cause the symptoms im having? the above problems are hapening quite often. Should I just reinstall windows all together?
I just put this system together. I bought the Motherboard refurbished from newegg. I have an athlon xp 1700+ in it. On bootup it doseant say Xp 1700+, it just says Athlon 4. It shows the correct Mgz. Do I need to update BIOS?
Thanks for your help
Shuttle AK31 w 512mb OCZ pc3000
Athlon XP 1700+
Geforce3 TI 200
Athlon XP 1700+
Geforce3 TI 200
