[OC] Jason aka LiquidFusion (Jun 05, 2001 12:10 p.m.):
You might want to check out an item called i think Digital Dan-it sits in a drive bay but i hear it is QUITE good
I think you might be refering to the DigitalDoc.
I had one there kinda cool can run 8 temp sensors and up to 8 fans.
you can place the temp sensors anywhere you get 2 diffetent types in the kit, it is a bay mounting kit. has a LCD screen that displays all fan and sensor info,it actuall very nice to have.
It was a little difucul to use though I had to turn on all the fans at once, not 1 by 1,the case neary flew away, but the one i had the DigitalDoc5 is the first to support 120mm fans that is why i got it, it did run the fan for awhile but the 120 over loaded it and kinda caught on fire.
So i wouldnt reconmend the 120mm fan feature but the sensors were great didnt have any problem with them at all.
