System wont boot.
D
DJ
Guest
I have an abit KT7-raid with a duron600@750. After I overclocked my system to 750 it wouldnt post anymore. When I first power it on all the HDD lights atc are on but the system doesnt post. When I shut it down by holding the power button for more than 4 seconds and than start it again it does boot. I have the feeling it has some thing to do with the overclocking but I dont know what or how. The Duron it at the default Vcore of 1.6V. Everything runs stable after it finally boots. So whats going on here?
Specs:
Abit KT7-raid (UL bios)
duron600@750
256MB PC133
Geforce DDR
2xIBM dtla 307030 (30G) in a raid setup.
I have experienced a similar problem with T-Birds. It disappeared with a months burn in. Try kicking your core voltage up a notch.
Colin
You'll probably need to raise the voltage to 1.65 or 1.7 to get 750 - that could be the problem. Another fix might be a bios update, look for one mentioning that problem. No need for a months burn-in if you leave the comp on for a few days (24hrs) running setiathome - if you don't have it already see the link on the frontpage, join the oc.com team!
Its at 1.7 now. I still have to push the powerbutton twice. Im not going to leave the PC on for a few days. Thats just a waste of energy. I think Ill just keep pushing the powerbutton twice untill its not needed anymore. Or maybe Ill raise the Vcore to match the standard value for the TBirds.
Thanks anyway.
I didnt expect anyone to pick up this thread. :)
Anyway, thanks for the info. I only went up to 1,75 but Ill try 1,85. Are u sure the duron wont overheat? I have a FOP32 cooler.
