sytem freezes
sparky
ive got :
amd tbird 1.33ghz
ecs k7vza motherboard
300 watt psu
32mg gforce gts agp graphics card
2 x 256mg s dram
20 gb hdisk
ive updated bios to latest version from ecs, but sytem keeps freezing randomly , tried variuos settings in bios with no success. ive ran sandra and there are no conflicts and everything appears ok.
help please as this driving me up the wall
Is the system overclocked, If so what is your FSB x multiplier settings ?
What are your tempratures ?
fsb is 2 x 133
cpu temp is running between 30 and 50c
the clock multiplier is set to default on the board
sparky (Jun 10, 2001 07:29 a.m.):
fsb is 2 x 133
sorry and it isnt overclocked and i wasnt intending to do so
Are these tempratures taken at idle or on load ?
Did you have the system freeze problem before you flashed the bios ?
tempretures are from standard windows use the 50c was when left running over night during which time it froze.
i had the problem prior to the bios flash which is why i did it
i have some more info if it helps motherboard monitor 5 gave these results-----------MBM----------
MBM 5.02
MBM 5 Core EXE : 5.0.0.2
MBM 5 Core DLL : 5.0.0.1
MBM 5 Settings DLL : 5.0.0.2
MBM 5 Dashboard DLL : 5.0.0.2
MBM 5 Hibernation DLL : 5.0.0.0
MBM 5 Ras DLL : 5.0.0.0
MBM 5 Logger DLL : 5.0.0.2
MBM 5 Mail DLL : 5.0.0.0
MBM 5 Heat Up EXE : 5.0.0.0
DLL Folder Location : C:\PROGRA~1\MOTHER~1\DLL\
Data Folder Location : C:\PROGRA~1\MOTHER~1\Data\
Language Folder Location : C:\PROGRA~1\MOTHER~1\Language\
Log Folder Location (Alarm) : c:\progra~1\mother~1\log\
Log Folder Location (High Low): c:\progra~1\mother~1\log\
Log Folder Location (Interval): c:\progra~1\mother~1\log\
Selected Language : English
Info ChipInfo.ini : 5408 bytes 01/11/2000 20:58:08
Info shdn.ini : 388 bytes 12/10/2000 17:47:06
Info Jedec.ini : 6321 bytes 22/09/2000 19:15:00
Info Language file : 16650 bytes 04/11/2000 10:04:40
------Sensor Chip-------
Main Sensor Chip : VIA Via686A
SMB Address : $5000
Used Bus : VIA686A
VIA686A Address : $6000
-Sensor Chip Selections-
Possible Temp Sensors[0] : None
Possible Temp Sensors[1] : Via686A-1
Possible Temp Sensors[2] : Via686A-2
Possible Temp Sensors[3] : Via686A-3
Selected Temp Sensors[1] : Via686A-1
Selected Temp Sensors[2] : Via686A-2
Selected Temp Sensors[3] : Via686A-3
Possible Voltage Sub Types[0] : VIA 686a Standard
Possible Voltage Sub Types[1] : Via 686a FIC SD-11
Selected Voltage Sub Type : VIA 686a Standard
--Sensor Chip Readings--
Temperature Readout[1] : 22
Temperature Readout[2] : 26
Temperature Readout[3] : 26
Voltage Readout[1] : 1.84693683409437
Voltage Readout[2] : 0.0632610350076104
Voltage Readout[3] : 3.40481735159817
Voltage Readout[4] : 5.15251141552511
Voltage Readout[5] : 12.3051369863014
Fan Readout[1] : 5443
---------System---------
Operating System : Microsoft Windows 2000 (NT 5.0) (Build 2195)
User : Administrator
Memory in use : 14%
Total Physical Memory : 523760 KB
Available Physical Memory : 447664 KB
----------CPU-----------
CPU Speed : 1335 MHz
Nr of CPU's : 1
-------3rd Party--------
ShutDownNow :
i have also ran a reg update from amd.com to clear up a conflict with geforce 2 and win 2k combined with an amd chip
Try taking out 1 stick of RAM. Sometimes, the RAMs do not match, or one is flakier than the other, which could cause lock-ups.
pqt (Jun 11, 2001 12:26 p.m.):
i tried this today and it ran for 6 hours then froze
Next step i would try is another video card, or at least another driver.
pqt (Jun 11, 2001 12:58 p.m.):
That happened with either stick of RAM?
no only tried taking out the new stick i bought when ipgraded the board , chip and graphics card . The other has been running A ok in another machine running a K6 500 amd. So i assumed it would be ok?
pqt (Jun 11, 2001 01:02 p.m.):
Cool i have tried the latest driver and ive updated the reg patch off amd site but havent tried a different card, i try taking out the other mem stick and then swap the cards . Thanks for the help and ill let you know the outcome .
just to let you know i tried all the solutions all with the same results the big freeze!!
so just out of interest i clocked it back on the jumper settings to 1 ghz and low and behold it is as stable as a rock!!! the trouble is i still dont know why it wont work at 1.333ghz. tech support at AMD and ELITE are shite.
so any more advice would be welcome
Yeah re-installed everything, flashed the disk and put it all back on with the latest drivers , i even tried a re-install with a different hard disk and had the same result froze at 1.333 but ran without a hitch at 1 ghz. Bought a new heat sink as i found the old on wasnt rated for 1.333 even though it was keeping the temp well inside the required level. Now got a OcUK super thermalright sk6 but no difference only the noise level has gone through the roof (looks nice though). Im thinking its the board but elite wont reply to mail?
Thought id let you know following over 2 weeks of argueing and returning indivdual components to the retailer, i today eventually got both sticks of 256 memory replaced as they say this the problem, after testing everything else. Ive run it for 8hrs and its ok , all i would say is thankyou for your help and dont let the retailer mess you around the way mine has for best of 1 month i got no joy until i threatened them with trading standards aurthority in the uk.
