- Dec 4, 2016
Hi everyone,
Finished my T-900 Thermaltake build and have a stable OC at 4.4 thing is I am a bit worried about the core v at 1.45. From what I understand the 6850 can tolerate a high voltage. Running Prime 95 I am hitting temps of 76-96c under full load and 32-45c under normal operation. Seems a bit high under water no? I have attached screenshots of the bios please have a look I know there are many of you with a high level of experience and see if something should be changed. Thanks!
