Alright this should be my last post This is kind of a long thing but if u can help i will really appreciate it. For the last 2 days ive been getting different asnwers on what fan to by. Please tell what fan to get if u are using it on a t-bird1.2ghz or higher. right now the fans im looking at are the fop32-1. The Taisol CEK 733092( ihavent heard much about this one, but it seemed pretty good here www.ocinside.de go to the thing that says u can hear the noise levels and theyll have a buig comparsion list of temps and noise) the coolermaster DP5-6H11-A1 or DP5-6H51-A1 i keep hearing about coolermaster fans on alot of places where u buy processors just not on sites like this. The fop 38 and alpha seem to make alot of noise. Just so u know i have NO intention of overclocking, just give me a fan that keeps it at a temp low enuff thatd it last 2-3years. My motherboard is the abit-kt7 raid with the 200fsb (not 266). So just tell me about the noise and performeance with a tbird 1.2 or higher. here are a few side questions that arent to important but it could help me a bit more
1.Has anyone heard of the twin turbo from www.3dcool.com. Ive heard at some sites that this is a power fan, has anyone used this?
2.Can some1 tell me if this case is any good heres a direct link http://www.coolerstar.com/atx400wmidto.html (this page doesnt take long to load on my horrrible modem )
3. last ?? the only fans that will be in my system so far is whatever cpu fan i choose and the fans that came with the case. Do i need more? If so tell me what type a fan and where to get it from, or see if i should egt the twin turbo( www.3dcool.com)
Well if u read all this thanks for all of ur helop i appreicate it.
