- Jun 19, 2001
- Marietta, GA, USA
First of all I'd like to state that I'm quite new to this field...So don't overload me with technical info unless you're prepared to explain yourself. That being said, I'll continue.
First, the system:
AMD T-Bird [email protected](Came like that.... don’t know...?)
Asus A7V Via KT133 chipset
384MB PC133
Herculese ProphetII GeForce2 PRO GTS 64MB DDR
Right now, I have some generic CPU cooler (looks similar to an ORB)
With case closed, under Idle(CPU) it runs at 133ºF-135º (Ouch!)
Under load, Case closed, runs at about 145(Getting scary....)
Case open - Idle, 120ºF-122ºF (A little better..)
Case open - Load, 127ºF-130ºF (Ehh...)
Recently I bought an 8" oscillating+ fan...
Case open, fan on, idle, 105-107ºF
Case open, fan on, Load, 107-110ºF
All right.... looking at these numbers, One would probably say that I need some new cooling. I realize that with the "case open, fan on" it provides 'decent' cooling, but I hate the fact that the case is open constantly and quite open to debris that could harm my hardware.
My current plan is to get a New CPU Cooler (Still deciding on which), and put an intake fan on the side of the case, and a blowhole at the top of my case. One problem...not enough room at the top.
I am wondering if there is an effective way to place both intake/blowhole on the same side panel.
I was planning on doing something like... Placing the Intake at the bottom right and the Blowhole at the top left.
This is my basic Idea based on...well nothing really other then that heat rises and the more appropriate place for a blowhole would be higher up.
So basically my questions are:
1. Which CPU Cooler (Under 50$) would you recommend?
2. Is the placement on those case fans good? What would you guys recommend?
Thanks for your help in advance, and also any other advice is always welcome
First, the system:
384MB PC133
