CrashOveride said:my friend has a T1 for ~1K a month, he sells service to a lot of people in his neighborhood via line of site sattelite i think... there is on braodband in his neighborhood- he gets fast speeds![]()
PsYcO CyBrArIaN said:I (almost )get T1 raw data transfer rates with my Motorola Cable modem and Mediacom service for 40 a month- 1.9Mbs DL/ my upload is for shiet though....just tweak those reg. settings baby!
pik4chu said:Im very sure that educational facilities get major discounts for things like that...pretty much everything for that matter
su root said:
OC (Optical Carrier) lines run on using SONET (Synchronous Optical Network). It's extremely high-speed digital fibre optics. There is no "NIC" per se.. the data needs to be multiplexed into the line.DDR-PIII said:there is OC-768 out too heh40gbps prolly more though.
oh well since were kinda on the subject now, does the signal of the lines that run under? is that also with one NIC ? haha or multi NIC's ? or do they use something else.
AFAIK, the forum servers are located at a server hosting site, where they probably share OC-3, T3, and T1 lines from different backbones.BGPatterson said:what kind of connection does this forum use? anyone know? just a curiosity.
The multiplexer takes input from a number of sources, and "queues" stuff to be put onto the fibreoptic line. SONET, I believe, uses TDM, Time-Division Multiplexing. Which means that every input connection has a timeslot of a few miliseconds every second. So every second of transfer has a little bit of data from each input. T1's and T3s also use multiplexing.
You should be able to find any terms you don't understand on webopedia..
np. Also-- I'm sure you've heard of "fractional T1's", right? A T1 consists of 24 "data" channels. A fractional T1 is buying one or more of those channels (and not all 24). Each of those 24 channels has a slot in the multiplexer. The slots that you rent can be used in the multiplexer. Each channel can carry 64k of data.DDR-PIII said:Thanks for eplaning that for me![]()
