blujay (Jun 20, 2001 07:15 p.m.):
Well I have tested the Geforce2 Pro DDR 32mg for a couple of weeks now. I have to admit that I have been very dissappointed with this card. Compared to my Voodoo5 agp 64mg I get quicker performance than I do with Geforce2. Had all latest bios and drivers installed. I will be exchanging the card to a 64mg version and give it a try. I even overclocked that card to 220/430 and it ran stable. But the performance was slower. I am sure it might just be me, but hope I won't be dissappointed with the 64mg version.
Asus A7V
Duron 600/950
512 micron pc133
ibm 60gig 7200 ata100
voodoo5 agp
You said "Compared to my Voodoo5 agp 64mg I get quicker performance than I do with Geforce2. " I don't know what you mean... in the 3D game? in the 3D benchmark?.. or... what API? (D3D/OGL for what game were u running?)
emm.. i think such problems like this people are having is usually caused by the "user", not the hardware's fault.
Is this your first time upgrading your Video card from Voodoo5 to a GF2 Pro 32mb?? There's difference between ugrading from a Voodoo card to another voodoo and upgrading a Voodoo to a Nvidia card.
If your GF2 Pro 32mb is performing poorly in your setup, then the 64mb will perform the same or even slower so you will not gain anything or actually get worse. So please check your Operating system. It can possibly be your vid driver, directX, conflict with your old vid driver that doesn't show on the Device Manager property which is
hiding in the registry, etc..
Azzkicker gave a good recommendation to someone in this forum on backing up Everything on a CD burner and then format HD/ install WIndows. it's up to you.
