- May 8, 2001
- Glenolden Pa
I recently told a few people what most case and mobo makers think about air flow . They like to see it drawn in the lower front and have it flow up across the cpu and then thru the power supply and out the back. I had my pc up on the bench the other day with the case open and said to my self " self , that big ( 6x6 ) reservoir is blocking your air intake " My case temps were ok mind you at 39C and the Athlon cpu is usually at 43C . I raised the reservoir with some plastic C channel that lets air flow thru and put a fan set that I had laying around under the reservoir to draw in air . They are almost in the middle of the bottom of the case and I can not hear them . They are from a cheap hard drive cooler. I drilled a few 3/4 inch holes just behind the intake area of the front panel. I also opened up the intake holes in the front panel just a bit. My case temps are now 31C . That's a big difference and I did not . ( see the pics )
Billy
Billy
