I can understand that your blocks are very limited in production.
I was just kinda joking, but kinda tossing an idea too.
See you wouldnt be building the blocks anymore.
Instead you would prep a design (on paper) then submit it.
After the first say 3-5 were built you could have one or two to test and they could test the rest.
Then you could either stamp it with your approval or adjust for further revision and testing.
The actual time required from you would just be to come up with the idea then test it.
They would do all the machining and labor.
Of course the testing is probably the most time consuming portion of the block building process (I wouldnt know
So maybe let them test them. and send one or two blocks to outside friends or facilities.
Im not trying to push anything Im just saying your the one with the golden ideas. Might as well get what you can.
I can also see how not getting that deeply involved would be worth alot too.
Either way you do a great job with your designs and you do make them available to the rest of us and thats enough for me.
Heck who could ask for more?
Late
Wardog
