TCCD 431 Max overclock with 1t enabled
Xtreme Barton
what is your max oc and what volatges are you using .. anybody tested the theory that tccd works better at lower latencies with higher voltages ??
Xtreme Barton said:
so far 300 fsb 1t 2.5 -4-4-7 @ 3.2 volts
Voltage actually helped??? What ram you running? G.Skill?
Anything past 2.8v is useless on mine. I get about 285MHz at 1t at 2.8v.
-Collin-
yes it does help for me .. for some reason i had to up voltage to get 1t enabled. but its running strong .. just got my personal best mem bandwidth score so far on this board but i am at 280 with it now.. had to use a divider ..
oh yeah i forgot to mention that they are PQI turbo 3200 2-2-2-5 .. brainpower pcb
