TDX help?
Revival
I just got a TDX with the extra adapters.
I have a 2 fan rad with mcp600 pump.
I only have cpu block on there now and could perhaps expand and put in gpu block as well.
What "accelerator nozzle" should I use? I was thinking of a 4?
I'm getting rid of my whitewater becuase of the 3 nozzle design. It would be great to get performance as close to whitewater as possible..
Thanks
The #5 performs the best, but on my RBX I get on an average of 2 holes plugged up after about a month of use. The #4 would be a good compromise tho since it shouldnt have any problems with it plugging up. From what I can tell it is about 1°c difference between the 2. The same should hold true for the TDX. I have GPU, NB and 2 120mm rads in my system.
#4 is the best to use. there is very little difference between the #4 and #5 temp wise. i use the #4 and i tested the #5 and there was only about a 1C difference in temps. so all in all use the #4 cause it wont clog like #5 will.
According to procooling #4 is the best, if you feel the need to swap out the gereral-purpose adapter. #5 is said to jam easily from any detritous in your loop..
Alright.
Running #4 right now
results
White water = 16.5 over ambient
TDX = 13.5 over ambient
Temps were taken at load with MB sensor.
THnks for the info guys...
Revival said:
Alright.
results
Was the WW dirty? The WW should be outperforming the TDX... Guess it could be due to the mobo/socket temp not being accurate and a different mount...
