TEAM CUP 2017
That's the spirit. Yeah stripped OSes aren't always the best. It might have been missing SP1
SC2: Stage 3 - Fire Strike Extreme GTX 700 (3 GPUs), GTX 780 Ti
I got a sub in at 5694 marks.
Not the best, but hard to compete with the newer LGA1151 and LGA2011-3 systems (they seem to boost the scores a good amount over what I'm seeing on my PC, especially on the LGA2011-3). Then there's the frequency difference, I'm surprised that competitor's 7350K is managing to get a higher score at a lower GPU clock but a higher CPU clock. I don't know if I can attain 5GHz, it may take more voltage than I'm willing to give my main PC's CPU.
Worst thing is even with fresh install of win7 not hitting anywere close to what I was hitting before . LOL with I could remember the tweaks I did on that first install 200-300 PPS higher .
Still messing around im not giveing in =)
Not the best, but hard to compete with the newer LGA1151 and LGA2011-3 systems (they seem to boost the scores a good amount over what I'm seeing on my PC, especially on the LGA2011-3). Then there's the frequency difference, I'm surprised that 7350K is managing to get a higher score at a lower GPU clock but a higher CPU clock. I don't know if I can attain 5GHz, it may take more voltage than I'm willing to give my main PC's CPU.
I feel ya.
If you don't have at least a 6600K you're not gonna be in there. There's a few stages like that this year.
I had to buy in. I have a 6700K coming.
WOW that 939 was very slow LOL painful to use
Try a socket 478 single core, you'll appreciate the speed of the 939 dual core then. My 478 rigs are frustrating to use, seems to take practically forever to load anything. Can walk out of the room to get a snack from the kitchen after firing the PC up, come back and it still won't have loaded the desktop.
Hay on another note not sure how many people are still using DDR you can make a submission for DDR frequency also.
Ok I got in the old acct how do I remove the other submition ?
-edit
I deleted it Will re add on old account
On a side note I tryed Windows.Tiny7.Unattended.Activated.CD.eXPerience from the OCF OS file it scored quite a bit worse than the reg win 7 that I was using .
LOL I cant even resub that run cause it was on the HDD I reinstalled on =( Guess I will just have to rerun and try and beat it .
Something doesn't look right here - It's showing that you used 2 X2 CPUs like you might see in a server and we know the A8N32 only has a single CPU socket.
I did check to see if it appeared in the X2 4400 listings and it doesn't, the current X2 4400 record shows differently than yours does as well in it's description: http://hwbot.org/submission/3209930..._r11.5_athlon_64_x2_4400_(toledo)_1.56_points
May want to redo the run to avoid problems.
Even though the CPU has two cores it's still a single CPU physically so you've have to go with 1X CPU when submitting, it's already understood it has two cores within it's description because it's an X2 chip.
Thanks Scotty, I have it fixed now so it shows as 1xCPU http://hwbot.org/submission/3594980
OK, got most of the stuff together for the party.
SC1/1: 7700/7600/7350K
SC1/3: 4770k
SC2/1: 8800GTX
SC2/2: RX 460
SC2/3: GTX 780
SC2/4: GTX 1080TI
SC2/5: GTX 980 CLASSIFED
SC3/5: 5960X
SC4/1: 6950X
SC4/6: 4770K
OK, I've updated the OP. I intend to keep a list there of all subs. This will make it easy to see for the rest of the team. I would ask when you post something could you use this format at the top of your post. Makes things easy for me to just copy and paste into the OP. Thanks
Tech Tweaker / 780 Ti / 5694
Just going to list what I think I can do
SC1-
Stage 1 - XTU 5GHz LGA1151 (5 CPUs) -- I have a 7700K and a 7350K that's it
Stage 2 - SuperPI 32M 5GHz LGA1155 (3 CPUs)-- 3570K mobo is soso
Stage 3 - HWBOT Prime LGA1150 (3 CPUs)-- 4790K
Stage 4 - GPUPI for CPU 1B Ryzen (3 CPUs)-- 1700X
Stage 5 - CPU Frequency Steamroller (2 CPUs)-- A10-7870k
Stage 6 - Cinebench R15 S939 (3 CPUs)-- if I can get my mobo working
SC2-
Stage 3 - Fire Strike Extreme GTX 700 -- GTX 770
Stage 6 - 3DMark Vantage GTX 900-- 980Ti/5960x hopefully LN2 on both
SC3-
Stage 2 - 3DMark01 GTX 200--- GTX 285
Stage 3 - PiFast LGA775 (3 CPUs)--- lots of CPUs
Stage 4 - Memory Frequency--- DDR mobo? DDR2, DDR3 no high speed sticks, DDR4
Stage 5 - 3DMark11 Physics Haswell-E --- 59060x
SC4-
Stage 1 - GPUPI 100M LGA2011-3 (3 CPUs)---- 5960x
Stage 6 - Geekbench3 LGA1150 (3 CPUs)--- 4790k
Stage 5 - 3DMark Vantage LGA1155 HD6000 HD6950 3570K
I have an old GTX 780IM going to try at the party,
- - - Updated - - -
SC1-
SC2-
SC3-
SC4-
How fast does your 5960x go, I was going to bring mine to the party, but if your going to do it IM not going to waste my time or the space, mine on goes 53-54 at best.
I've never wound it out with LN2 yet. I was hoping to this summer. Just one of those CPUs I haven't gotten to yet. It does well on chilled water though IIRC 5.0 XTU with ~ 1.3V
