- Jan 12, 2012
On my 955 I used to run my Cpu Nb Voltage around 1.2-1.25v take into account this will raise the core and socket temps a bit. You'll know it needs tweaking if it's unstable.
AgreedIf it aint broke, don't fix it.
CPU code is just that, adding support for new CPU's. If your CPU is already supported, which it is, then the bios update does nothing for you.
Too late on that one since I already ordered the 4350, I couldn't pass up on a deal on a better and faster cpu new in the box for a cheaper price than what I originally paid for my Phenom. However, I am wondering if there was a specific reason why you said that.I also wouldn't get a Fx chip and try running it on that board.
The Phenom II x4 965 BE is a 3.4GHz 64 bit cpu, with 4 x 512KB L2 Cache and a 6MB L3 Cache.I said don't buy the Fx 4350 because it's not that great of a chip
If you're being serious and legit then you're on buddy, just tell me how you want to do it.Send me the 965 with the bent pins and I'll send you a processor so you can flash your board.
Good work Scotty!Send me the 965 with the bent pins and I'll send you a processor so you can flash your board.
