- Nov 15, 2008
- San Deigo, CA
I was wondering if anyone here has ever come across using this ram and REX combo before. I am about to get the Team Xtreem 1866Mhz DDR3 ram and a very nice E8600 very soon to go along with my REX motherboard and I was hoping to squeeze every little drop out of this RAM and CPU on high end water. Just curious to see if any one else had successfully clocked this RAM to 2000Mhz+ without too much problem. I'm hoping to get around 4.7-4.8Ghz prime stable.
Specs of the new build.
Motherboard: Asus Rampage Extreme X48
CPU: Intel E8600 Batch Q820A405
GPU: Sapphire Vapor-X 4870 512MB
RAM: Team Xtreem 1866mhz DDR3 2GB (2X1GB)
WC Gear:
Cpu Block: HeatKiller 3.0 CU LGA 775
Radiator: HW Labs RX360 W/5-6 yate loon's high speed fans.
Pump: Dual DDC 3.2 pumps (it might be overkill for just cpu only loop, so I might just sell 1 if there is no performance increase by using 2)
Res: 2x EK400 res. and EK Dual pump top/dual bay res for DDC pumps (will just use 1 of the EK400 res if I go with single pump and EK top for the pump) and 1/2" tubing through the loop.
Will this WC be enough to pass 4.7-4.8Ghz 24hrs prime test? I have seen lots guys on High end Air do 4.4-4.5Ghz on E8600's at bunch of forums below 70*C. Maybe with this very good water i can do a bit higher and stay within 70*C. I would appreciate your guy’s thoughts and comments on this. I’m wondering if the RX360 is good enough or should I have gone with PA120.3 or something similar.
WC Gear:
