- Apr 23, 2001
- Indiana, USA
Ok, this seems too simple, so there must be a reason it's not done...
When I look at my P3 and see that all the surface I have to work with for heat transfer is that little half inch die square, I started thinking. A lot of heat radiates out into the material around the die. Removing heat from there seems like it would lower the temperature of the die. So...
Could you...
Hollow out a space (like with a router) in the center of your heatsink, slightly bigger than the die and as deep as the die is high. When you re-apply the heatsink, you would bring metal into contact with the material upon which the die is mounted, giving your heatsink more area from which to remove heat.
Lemme know what makes this a bad idea...
G
Could you...
G
