tell me what you think!!!!!!!!!!!!!!!!
Wolfeinstein
Disabled
CA
i'm planning to get a power supply im running athlon 2000+ a7n8x mb 512 mb ram dvd,cdrw,1 HDD ,4 case fans, ati 9700 pro these two choices i picked out i have no budget for more expensive psu spent too much on a new puter already.
could anyone tell me which would fit my needs better.
Thanks for your response!
http://www.newegg.com/app/ViewProdu...=58&manufactory=1919&DEPA=1&sortby=14&order=1 i picked the fortron fsp 400 pfn for 60$
and
http://www.newegg.com/app/ViewProdu...=58&manufactory=1231&DEPA=1&sortby=14&order=1 enlight 420w for $ 55
Thanks all!!
Wiz4rd
Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron Fortron
larva
Inactive Moderator
Newegg has a killer deal on a power supply that is up to your application, the Fortron 350W model for $32. Unfortunately they are out of them, directron has the next best deal:
http://www.directron.com/fsp35060bn.html
The fan does tend to be noisy, the reason I suggest getting the supply from directron instead of getting the equally priced Sparkle 350 (the same supply) newegg does have in stock is because directron has a good deal on the best fan to put in the supply if noise is a concern:
http://www.directron.com/80l1a.html
By this time, at $44 though, you could have almost bought the real solution: the 120mm equipped 350 Sparkle version (Fortron owns Sparkle and makes the supplies) that xpdirect has for $48:
http://www.xpdirect.com/35sparpowsup.html
larva
Inactive Moderator
O yeah, the Enlight is made by the Sirtech Group, www.topower.com. They are decent supplies but the 350 sparkle is stronger and costs less, even in its 120mm fan version.
CrashOveride
Beijing, China
larrymoencurly
should i get the antec true power 430w or 350w true p???????
That's a trick question 'cause there is no 350W TruePower.
