temp at GPU?
Kato
Addicted Tweaker
Toronto, Canada
Hey guys, i've just put a Corb on my ti200, and overclocked it to
225/500, and after running 1/2hr of 3dmark2001se, the GPU temp is around 39C.
1) I've never checked the temp of the GPU, is this a good temp?
2) What temp do you guys usually get?
3) Is my 225/500 any good?
Thanks!!!:D
NASsoccer
On a string I was held Senior
i live
don't know about the overclock since i have a reg gf3 at 250/560 but my temps on my card are usually around 35 or so , so i would say that those temps are pretty decent especially after a good 30 min of benchmarking
DDR-PIII
Disabled
6p6
my voodoo4 4500PCI has a faster core speed than the 1st GF posted.... It's got a core speed of 230 OCed with.. V.Control :) and HELLA LOTS COOLING from air...-30-
WillysNut
Senior Jeep Nut
NY, USA
Not that this is the end-all-be-all but check out this page over at Anandtech. Looks as though with stock cooling, the lowest temperature of 4 different Ti200 models was 46c. The other three models were at 50c and 52c and 55c.
Quite an improvement on stock temps eh? :D
Dissolved
OC California
VisionTek Xtasy 6964 140 F / 60 C 260/580 MHz TV-out, DVI-out $320.00...
i guess they mean by stock cooling, but ive killed them with my oc.. :) 275/595 has been my highest running 3dmark.
