ok, Temp controlled fans sound like a good idead, right? Right, but they are completely dependant on the positioning of the temp probe. Right now I have two temp controlled fans in my case.
One is in my enermax PS, there's is hardly ANY airflow out of that thing, and then theres my 120 mm intake, once again VERY little airflow.
Now, the enermax I'm not going to deal with right now.
It's the 120 that irks me, because, well, frankly I know I could get alot better airflow out of it, it's basing it's Rpms on the temp of the air at it's coldest point in my case, WHERE it enters it. , which means it runs at a consistently low speed. sure the fan runs quiet, but I don't care, because I can't hear anything over the noise from my dragon orb. Feeling like getting a volcano 7 and having the speed adjuster.
Any one know how I can either just work around the thermistor on the fan, or where I'd best be able to place it if I stuck it on more wire, or if I can jsut clip it, or SOMETHING?
also, getting that enermax fan running faster would be nice.
right now my case temps are pretty low though, but I want them lower, because lower case temps, should hopefully mean lower CPU temps.
got advice? got questions? got suggestions?
