Temp probe
f155mph
I got a P4 northwood and I am trying to mount a temp probe on it. The only place I think I can mount it is on the side of the cpu. The only thing is that how can I make it stay without gluing the probe on the cpu? I used double sided type like the one use for ram sink. That work ok for a little bit but it didnt last. When the cpu heat up it loose it stickiness. Any suggestion?
