CPU Temp Reaches 90 degrees then cuts out. help plz
Hi,
im running :
Athlon xp 2200 with Asus A7N8X mobo
Asus Geforce 4 ti4600
512 DDR
WIN 2000
im using the default fan and heatsink that came with the processor. i have a 120mm Fan stuck right next to my graphics card , and a 80mm Coolermaster chassis fan placed on the back of the case.
i dont know why the cpu temp is so high. im having to run the clock speed at 1800 instead of 2200 just to cool it down to 85... the cpu fans running at 5000 rpm on the bios.
can anyone tell me the problem? and a possible solution?
thx for your help.
Hi,
im running :
512 DDR
WIN 2000
thx for your help.
