Temp reading backwards
blueknight1960
VA
Hi all, I have a friend who just got a pre-built AMD cpu desktop computer. I noticed that the idle temp is around 55-64 c. I installed the intel burn test and when run, the temp drops down to about 34 c and when the test is stopped,it goes back to 55-64 c. I was thinking a connection for the temp reading is connected wrong? I'm not sure how to correct this. Any help would be appreciated.
caddi daddi
Godzilla to ant hills
you are using amd overdrive, it shows how many degrees until you reach the max temp of the processor.
blueknight1960
blueknight1960
VA
Thanks for the reply. Guess it would make too much sense for amd to do it the normal way.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
There are a couple programs that do it that way, actually. Realtemp (for Intel) shows both.
EDIT: I personally like seeing it that way as without, you have no idea (without researching) what the limit is/how far you have to go. ;)
blueknight1960
blueknight1960
VA
Once again it's not my computer, I was looking for a friend. But I appreciate the feedback.
caddi daddi
no problem, we like the easy questions, makes me look like I know something............
EarthDog
Buckeyes!
Once again? BK, it doesn't matter who's computer it is... I answered a generic question with a generic answer...computer ownership agnostic. :D
