temperaturemonitoring help
bananablack
virginia beach
temperature monitoring help
i am using 3 sources to monitor my temps. they all give me large differences. im using mbm5 it says 38 deg c, sandra says 49deg c, and the one that came with my mb says 54deg c. which is more accurate. im running an xp3000+ stock, msi k7n2d mb, dd rbx, l30 pump, blackice pro radiator.
vonkaar
Colleyville, TX
Have you flashed your Bios recently? The K7N2 had *horrible* temperature fluctuations in early BIOS releases. Also, run core center... it helped stabilize my temp readings... should come with your board utilities.
