Temporary graphics card
Oakyy
I currently don't have a graphics card as my old one broke an old 2gb GeForce gtx
So I'm looking for a cheap temporary graphics card under $70 while I save up for an evga GeForce gtx 1070
I was looking at something like a gigabyte GeForce 710 for the time being
Is it worth it, or should I just wait
O
Oakyy
I5 4460k I think
- - - Updated - - -
It was a pretty big downgrade going from my old GPU to the onboard graphics
rainless
Old Member
You can get a GTX 570 for around 40 bucks. Maybe even with 4GB. Has a wider BUS and should be faster than a 710.
[email protected]
Israel
The Gtx570 should be around Gt740 performance.
If its temporary i would suggest the iGP, If you want something stronger just buy a decent GPU so you wont regret it if your main GPU dies, I would suggest something from the 5xx and 6xx series for nvidia and HD7xxx series for AMD.
||Console||
760ti
Rx460
660ti
670gtx
770gtx
280x
7950/70
Any of those should be in your price used .
Suppressor1137
I've got a GTX 770 2g card here that I'm going to be selling soon. If you are still looking, and I'm still looking for a buyer in a month or so, maybe we could work something out. I'm using it right now, and it runs every game i throw at it really well, but lacks the ability to really have any chance at the latest and greatest in gpu shredding games due to its small vram.
BUUT, I still vote to use the IGP if it is temporary.
Most games are locked at my refresh rate, while some newer titles struggle with max-medium settings(depending on the game).
Brando
last time i was in your position i went to a local hole in the wall computer parts place and asked for the cheapest pcie card available. he gave me a used nvidia something or other for $20 and it worked fine. got my screen to turn on so i could internet and check on my warranty for my real card. that's what i would do.
MikrotikSi
Temporary graphics
Всем привет Есть конфиг:
Мать: GIGABYTE GA-EP31-DS3L
РџСЂРѕС†: Core 2 Duo E7200
ОЗУ: Corsair XMS2 cm2x2048-6400c5 4ГБ 2x2 планки
Видеокарта: ADM Radeon HD 6670
БП: Vento ATX-450D
Система работает более менее стабильно, при входе в Биос выдает вот такое вот сообщение Warning: Graphics card is not guaranteed to operate normally., что это значит?
