Can anybody help me here Im here is my computer specification
Number of CPUs 1
Cpu Name AMD Athlon XP (Barton)
Specification AMD Athlon(tm) XP 2500+
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
Cpu Clock 1837.5 MHz
Clock multiplier x 11.0
Front Side Bus Frequency 167.0 MHz
Bus Speed 334.1 MHz
L1 Data Cache 64 Kbytes, 2-way set associative, 64 bytes line size
L1 Instruction Cache 64 Kbytes, 2-way set associative, 64 bytes line size
L2 Cache 512 Kbytes, 16-way set associative, 64 bytes line size
L2 Speed 1837.5 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Motherboard manufacturer MSI
Motherboard model MS-6712, 1.0
BIOS vendor American Megatrends Inc.
BIOS revision Version 07.00T
BIOS release date 04/02/01
Chipset VIA KT400 (VT8377) rev. 0
Southbridge VIA VT8235 rev. 0
Sensor chip Winbond W83697HF
RAM Type DDR-SDRAM
RAM Size 512 Mb
RAM Frequency 334.1 MHz
RAM Interleave 4-way
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 7 clocks
# of memory modules 1
Module 0 DDR-SDRAM PC2100 - 512 Mb
AGP Status enabled, rev. 2.0
AGP Data Transfert Rate 4x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 128 Mb
Windows version Microsoft Windows XP (Build 2600)
But I dont know if it is running too hot because its 55'C.
I dident make the computer so I dont know what heatsink/Fan I have got in.
If there is a program 2 tell you can U give me a link or tell me the program name and is my Computer running too hot
Number of CPUs 1
Package Socket A
Technology 0.13µ
Bus Speed 334.1 MHz
L2 Location On Chip
RAM Type DDR-SDRAM
RAM Size 512 Mb
