Ingo (Jul 17, 2001 07:33 p.m.):
Good to hear. I assume you still have it mounted inside the case and the case is closed? Do you have the pump between the fan and reservoir or the other way around (assuming you have the radiator and fan at the lower front of the case)?
peewee (Jul 17, 2001 06:50 p.m.):
well my temps with the pump mounted outside went down 4c! now im at 35c at 1.55ghz and 1.8 volts... and my moboard temp is at like 31c room temp is 28c....is that good??
bdf24 (Jul 17, 2001 09:23 p.m.):
Mount the radiator outside the case and I bet your temps will drop a lot. It is inconveinent though, I know.
bdf24 (Jul 19, 2001 12:34 a.m.):
The case fans will effect your motherboard temps a lot more then your cpu temps. But it may drop your cpu temps a few c.
