Strange things them cpu's...... Its good to get stuck into something now and again isn't it![]()
Rgone it sure seems that the HT Link sp/NB Freq need to go up in scale when you get to those high CPU mhz.
Cpu-nb is very important for memory tasks. But scores don't scale at all by pushing higher that link.
I have never lowered the HT Frequency that low on my earlier 8120 nor the newer 8350. 2600Mhz was the default on my 8120 and the 8350 so I have kept HT Frequency up close to that, except for this foray back down towards 2400Mhz HT Frequency for "keny".I.M.O.G. said:however htlink has no effect on performance in my experience for piledriver between 1600-2000mhz
It be interesting to see how the 8350 does compared to your H20 setup. Which heatsink did you purchase if you don't mind me asking?I bought the #3 ranked Air-cooler over at FrostyTech and will make it push-pull not just push
@ "Mandrake4565", what I hit or missed on is described below.
Aegir SD128264
Xigmatek S128264 Aegir Stacked Heatpipe Heatsink Review
Well the list a SS Phase as #1. Hehehe. The Noctua NH D-14 is a shaded quieter but not quite as good in cooling.
Would be splitting hairs to decide which would be better. I have had a lesser and cheaper 90MM Xigmatek and it performed on-par and often better than higher priced coolers a few years ago so I just decided to stick with a brand I knew and it having a good rating.
I knew better than to think a CM 212 EVO would handle the heat at what was 4.5Ghz and now 4.6 and 4.8Ghz so had to go with one of the big boys.
The Aegir SD128264 and the Noctua NH D14 are both tested with a push fan only. I bought a Xigmatek fan rated slightly 'higher' than the push fan to use for the pull fan. We will just have to see.
RGone...
I need to know what cooling are you using Rgone?
I know its water cause there is noway on air
I am reading up on water cooling still have a ways to go but its nice see that you can get pretty high up on the clocks
Thanks for the heads-up. If I ever decide to DICE, that no loss from lower HT Freq. will be good to know.
RGone...
You know you want to![]()
