FRONTPAGE Testing PWM Fan Combinations on the NH-D14
Here we will look at a variety of 120 mm PWM push fans on the Noctua NH-D14 while using two different 140 mm PWM fans in the center. Noctua has sent three PWM fans so we finally have what I need to make some comprehensive comparisons. Those of you who have PWM-only control of your CPU fans (most of you) can now control fans on your NH-D14 with your motherboard. When your CPU is idling your CPU heatsink fans will be running slowly. When your CPU loads up, your heatsink fans will speed up. In this study you...
