I've heard and read that people testing the TH7-II boards found the temp sensors to be 7-9C above actual, is this just system or CPU diode as well? I just OCed my 2.4B and am running up to 48C flat under full load using winbond monitor v2.7 This doesn't seem right as my OCed and higher voltage 1.5 @ 1.7v only ran 48ish too. I'm at a loss, I've even tried both HSF, the one from the 1.5 and the new one, the old one cools better by about 2C and that's just 5 hours after throwing the ASII on it so it should drop another degree or so, just wondering if there's any definite proof about the temps on this board. Oh and whether the VCore is correct as well as it is waaaaay too low in winbond monitor...
I know these are problems with this board, but it's been a while since this board was discussed in depth and I can't find links, if anyone remembers the links....
Thanks.
Thanks.
