TH7-II VCore
Cooler666
Disabled
Winbond Hardware Doctor says that my Vcore is 1.44V and sometimes shows 1.47V and this is below the low limit, therefore it gives me an error alert to do something about this. My voltage in my BIOS is 1.5V, is this right? or do i have a problem with my sensors or is the power supply not good?
thanks
Floodblur
I read this in one of the boards reviews just a few minutes ago. Look for Batboy's post on the intel board about the TH7-II. THey said that the board supplies about .05V less than the setting you apply.
mikeward
Atlanta, GA
I've got the same thing...I think I read that your SoftMenu settings lie about what the voltage is REALLY at. I bumped mine up to 1.55V (or maybe it was 1.575) and that keep the voltage pretty much at 1.50V (according to Winbond). But, you're always going to have a little fluctuation in your voltages across your board...as long as you're not jumping all over the place, you should be fine.
