Thank You All! OverClockers <3 Woomack/EarthDog/Trents
lIrenicuSl
Hi!
I would like to thank all of memebrs on this forum, wich helped me to choose an PC build, special thanks to
EarthDog- for private message support with Graphic Card and PSU topic.
Woomack - For support with almost everything: CPU/Cooling/Motherboard/ RAM memory and many many others. Dobra flaszka Ci sie nalezy za pomoc, szkoda ze oboje za granica siedizmy, jak bedzie kiedys okazja mam nadzieje, ze uda sie ja spozytkować.
trents Alaric Nebulous caddi daddi ATMINSIDE - For help with PSU, wich was a bit confusing problem.
Thanks also to all others wich i forgot to mention.
Here is short video for You guys, and screen;
http://imgur.com/a/k0ExT
https://youtu.be/UPxNwKsnHko
PSU and Cooling i will recive at next weekend, stay tunned!
dejo
Senior Moment Senior Member
there is a ton of knowledge and personaly experience here. and a great group of people
trents
Senior Member
Thanks for taking the time to express your appreciation. It's always refreshing when someone does that.
L
lIrenicuSl
Just one of my dream comes truth,I'm not even joking.
Wheen I was 17 i alwyes wanted to have "TI" and top processor, and now it's ani7 [ i7 ddint existed when I was a kid]
I will put pictures ofall components later, and maybe short video of making PC, i was using phone, quality isn't so good
RollingThunder
Destroyer of Trolls & Spammers
Hi!
PSU and Cooling i will receive at next weekend, stay tunned!
None of this surprises me, most of the above mentioned (and others) have helped me with new builds and questions. :thup:
L
lIrenicuSl
Im confused <?>
Well I'm confused, In a moment where you plugin the cables, check this out guys, and please answerme 2 questions:
1: Does it matters how do i plug in RESET Switch/ Power Switch? There are no informations on instrucion/motherboard where is + where -
http://imgur.com/a/juptn
2: On my Tower I got few cables what I don't understeand, and don't know what to do with them. I'm supossing its an power supply for Tower coolers, when you can't plug IN them to MOBO, but i got one with cables from front panels too..
http://imgur.com/a/Ki1ZP
Can someone epxlain me for what is this 2-pin cabel? the Coolers got 4 pins.
dejo
1. orientation wont matter on power or reset switches, but can in the ones that control lights. correct orientations is usually with the little pads to the inside.
2. that is a molex connector. I would guess it is for a fan if it comes from the case rather than the psu.
L
lIrenicuSl
1; thanks
2: Not Exactly, and thaths the point, i got 3 fans and x4 molex
3x molex are 4 pin [ so its from fans] - wich i understeand can be used insstead of MOBO plug-in, when there are no slots
1x molex is 2-pin and it goes from FRONT panel, with AUDIo/USB 3/ USB 2/ HDD connectors, i don't have clue what is he for...
dejo
would guess maybe its for some lighting from the case then
L
lIrenicuSl
I don't understeand wht it has 2 pins only, you can see it on picture, i dont even know if i got such an molex on my PSU
or maybe i shouldn't use it if i made all others connectors into MOBO.
caddi daddi
Godzilla to ant hills
that 2 pin plugs into a fan header on the motherboard, you can power those fans with a molex from the psu, or a fan header on the motherboard.
L
lIrenicuSl
thing is this molex 2-pin goes from lamiante where are all connectors [AUDIo/USB 3.0/USB 2.0/ HD led/ POWEr switch/RESET switch] and so on.... not from FAN. and I'm wondering if Front panel is going to work w/o it.
