- Jan 10, 2012
what case are you using, so we can goo look at the manual.
See those blue lights at the top? The molex connector should power those leds if I'm not mistaken.
Just plug it into one of your psu molex leads and everything should work.
If a connector comes attached in the case, you will want to plug it in to ensure you are getting all of the features from the case.
Whether the connector has two pins or 4 pins doesn't matter so much, unless you have a device that requires all 4 pins AFTER the one with only two. Think of it as a rope with 4 strands. You want to keep all 4 strands until you no longer need them. If you add a device later that has 4, or 3, then plug it in before the molex shrinks down to two wires.
I just try to make it as easy to understand as possible. I didn't mean to offend if I did.
the 1x2 is the one you use with the 2x6 to get 2x8. It's a compatibility first design.
- - - Updated - - -
as for the 4x4 pin, those are for cpu power.
oke so seems im gona miss some pins, i think need an "converter" or however its called from MOLEX into 8-pin pluger
Could you link the PSU you have? You want to avoid molex converters like the plague.
