Well, Its been about 2 months since I started my Water cooled duallie and its finally coming to and end today. I just hooked it up and booted bios to see my temps. They were CPU 1: 44 C, CPU 2: 37 C
Well, this is pretty good for a first boot. Its filled with bubbles and the AS3, is breaking in. Anyways, Im gonna unmount the blocks and cut some tubing, I used too much to fit in the case on accident, this should lower temps a little also.
Mobo: Epox M762A
Procs: Athlon MP 1900+ (2)
W/c: (2) D-Tek Hi Flow Spirals w/ Aluminum Tops
Chevette Heatercore
VIA Aqua 1300
1/2 In Tygon
170 MM Fan, 240 CFM, AHhh! (I have another that I plan to mount as a puller for the rad. Scary isnt it?)
Anyways, Thanks for all the help. I could never have begun my quest into water cooling without the help of all your forum goers. I plan to stick with water cooling and learn more. Possibly go wit h a Water chiller or Peltiers on my next puter, Who knows, but I mean it when I say thanks. Ill put some pics up as soon as I find my XP Pro disk and Redhat 7.3. Heh, Anyways, Keep on coolin'.
Mobo: Epox M762A
Chevette Heatercore
VIA Aqua 1300
1/2 In Tygon
