- Dec 19, 2012
OK, this summer is nearly a repeat of last summer's 4x4.
This time around I have selected 4 benchmarks that are to be run at 4.5 GHz on 4 cores with HT/SMT if you have it. We're also going to substitute Benchmate here for monitoring. Download the "Big" pack which has the CB and 7zip benchmarks within it. Run the benchmarks from the Benchmate console and hit save when finished. This will bring up a results window that is needed along with the CPUz tabs. HWBot x265 has it's own timer so it should show accurate results for the speed if I find it doesn't we'll have to add HWInfo. I have included a link for HWBot x265 below. So without further ado here we go:
What: 7ZIP, Cinebench R15, Cinebench R20, and HWBot x265 1080p
Who: any forum member
CPU: any CPU limited to 4 cores plus HT/SMT and 4.5 GHz can have more cores but must be disabled in BIOS
Cooling: Any
When: Ends: August 21, Midnight EST
Full Competition Rules: Here
As was stated a 4.5 GHz limit is in effect with a 10 MHz leaway (4510 MAX) as well as 4 cores. I ask that any submission that's put in uses Benchmate for monitoring speeds and must be open during the benchmark. CPUz tab must show only 4 cores being used so disable any extras in BIOS beforehand. The final score will be the total from all 4 benchmarks and please include this in your post. Also, use the supplied background
I would also like this format used at the top of your post and tally your scores for me please UserName/CPU/Score
BACKGROUND
Johan45/ R9 3900X/ H2O/ 52376.283
Johan45/ Ryzen 9 3900X/ H2O/ 52,232.283
dejo/ 3700x/ AIO360/ 52217.29
dejo/ Ryzen 7 3700x/ 360 AIO/ 52080.29
bassnut / 3900X / H20 / 50761.459
mllrkllr88 / 3900 OEM / AIO / 50394.718
jiccman1965/3800x/LN2/50,257
mackerel / 3700X / air / 49561.401
CADDI DADDI| 8086K| H20|40301.639
mackerel / 6700k / air / 41000.661
Caddi Daddi| intel i5, 4460| 20844.242
Cooling: Any
BACKGROUND
