- Mar 29, 2002
- IL
Ok, I think I know what the problem is. I think there was a post similar to mine by Tantanum or something ... but if you read his, and if you read mine, they're similar, but different.
Well, I only installed the CPU, heatsink, video card, hard drive, floppy, and cd drive. I have only a 300 Watt power supply, but that's not the problem. See, this is my first computer I've started building. Well, I flick on the power switch, push the power button, and lo and behold, the fans start to spin! I do a little happy dance, and turn on the monitor, thinking all is well. It says there's no signal cable.
I have just checked the GeForce II I had on my new computer (it's in this computer right now) and it's fine. Counter-Strike runs at 45-48-ish FPS. Don't know if that's right or not, but it's better than by 18 FPS TNT.
The heatsink is a Millenium Glaciator II; I think I did something to the CPU, but I don't know what. I checked the core, and to my eyesight, nothing is chipped. But if something was wrong with the core, the blank screen would result, right?
