- Jul 9, 2007
Is this it? http://www.newegg.com/Product/Product.aspx?Item=N82E16813131237
(Of course, the price has to be less than $150 )
there was a nice article at Anandtech yesterday about how the AMD 780G chipset has better integrated graphics than the Intel G35, but it all depends on what you plan on actually using the computer for and if you already have a intel proc are looking to drop in or if you are open to buying amd.
this is the article: http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3258 and this is the mobo they reviewed: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128090
Alot with that crappy PSU, get a decent one.
HUH? It has an 86%+ efficiency rating.... and is also labeled as "green".....
With the discontinuation of the GA-G33M-DS2R (RIP!) that Asus board is pretty much the best. If you can hold off a week or so, look into the GA-Q35M-S2. It's just being released now, it seems, and should stack up well.
Newegg has it listed as "80 PLUS", I guess I could be wrong... Link to search.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817426003
Efficiency up to 86%
a better choice
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
or if you want to spend close to what the b-Tarantula is . this one is $5 more but also a bigger psu.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
both have mir's so in the long run both are way cheaper.
