The Case MADE for water cooling!
Magnus
canada
it is complete at last....
next! : lian-li pc65b with a plexi bottom! stay tuned!
Magnus
Magnus
canada
31c idle, 34-35c load.. i got a heater core and regular rad with 2 120mm fans cooling the cpu block! :]
juliendogg
NC, USA
Nice work! I'd been thinkin about something like that myself. everything is so crammed inside my cheap mid tower, i got a huge heatercore mounted in the top 5 1/4 bay, and an ehiem 1250 supervelcro'd to the bottom. can you say tight???
nice clean job, i luv it!
J.
Epox
Ohio
Ok man, your images are broken. They are not comming up. I get a red X, even after refreshing the page multiple times. etc..
Epox
Ohio
I just want him to fix his images, there should be a rule again broken links...
Michfan
Alabama
Works fine for me. Just go drink some more coffee then maybe youll be less grumpy in the morning.
Magnus
Magnus
canada
Silversinksam said:
Magnus, Thats really great and If you dont mind I think I may try to emulate this in my next case I buy
nope... go for it... i already won in a case mod show and glow. :p
couple tips... a sheet metal break(bender), die grinder, and good snips are the key. i used 8th inch alluminum in champayne metallic color. also i rivited it to the bought case and cut a hole for the water tubing. good luck!
HERE is the link to the show and glow
also i have the pics hosted by villagephotos.com. they only give me 5 meg bandwidth a day. so if they dont show up check the next day...
