- Jun 28, 2012
Ok so to be clear on this you have a 4pin(AKA PWM fan) attached to a 3 pin fan header and its not working consistently?
If thats the case my suggestion would be to buy a standard fan. The problem is likely that since the fan isnt receiving PWM signal its occasionally just going stupid. Simply bridging the pin 4 to pin 2 might solve this issue because AFAIK PWM to ground is full speed signal, but realistically your running the wrong type of fan, and issues are to be expected.
From what I can tell the fan has both 4-pin Molex and 3-pin fan header.
