The Last Piece of Oc'ing the case
NASsoccer
On a string I was held Senior
i live
ok, it is a sweet looking case. I like the color scheme and all but i am not too fond of the size. I like mine with a little bit more room on the inside. Also the vent is one of the sweetest things about the case but i would much rather have the ability and room the put a decent size window and some active cooling in there, unless of course you are going to water cooling then it shouldn't be a prob at all. All in all nice case.:)
T
triflux
Disabled
New York
Actually Singmin cases are a bit different. They use a "card cooler" system which lets you hang more fans in differnet locations etc..
here are some pics of it on an older model
thanks for the opinion NAS
GeckoBanzai
WI
case
The case looks good and seems to have plenty of room depending on how much you're going to throw in there. The card cooler solution rocks. The best part is the case looks sweet and the price ain't bad either.:)
David
Forums Super Moderator
Having fans above the mobo is a fantastic idea. My temps dropped quite a lot when I 'dangled' (using tape :rolleyes:) a fan over the CPU HSF. Very useful.
